C72 from France
sky.fred
Re: C72 from France
Post by sky.fred » Sat Feb 24, 2024 9:46 am
Dismantling continues.
the oil pump strainer screen is partially missing, and what little remains disintegrates when touched.
The pump shows no visible damage or residue. I'm going to open it up to check that pieces of the strainer haven't been swallowed.
I found a new strainer in an old stock to replace it.
Geoff Hastings
Re: C72 from France
Post by Geoff Hastings » Sun Feb 25, 2024 6:16 am
The rust on the frame is a real pain, I would get it shot blasted to show any other areas of concern, my C95 was really bad, right on the verge of not being repairable.
Michael Stoic
Re: C72 from France
Post by Michael Stoic » Tue Feb 27, 2024 1:29 am
Great to see you diving in, Sky Fred! From the couple of glimpses at your garage and your method, I think the bike is in good hands!
Geoff, I'd love to see the following three photos of how your fender/frame repair progressed.
Michael
sky.fred
Re: C72 from France
Post by sky.fred » Tue Feb 27, 2024 2:07 am
I'm starting to get the hang of it.
Since I've retired, I spend more time in the garage than in my living room, doing motorcycle mechanics for myself or for friends.
My latest work
Honda XR 500 R 1982
Honda 1000 GL 1976
Honda 125 cbs 1972
Moto Guzzi 1000 S 1992
sky.fred
Re: C72 from France
Post by sky.fred » Tue Feb 27, 2024 6:34 am
Returning to C72.....
The frame doesn't have any weaknesses but the welds aren't very nice and will require a lot of cosmetic work to make it look good. I'll do that later as my seller had another frame in very good condition and I'm going to mount it once sandblasted and repainted
The saddle is .... how to say .... The foam on the passenger seat is as hard as concrete and the rider's is disintegrating.
I'm having it redone by a saddler friend of mine with a havana brown covering.
Geoff Hastings
Re: C72 from France
Post by Geoff Hastings » Tue Feb 27, 2024 12:20 pm
Hi Michael,
I did post the completed frame repair a while ago but for those new to site I’ll show the photos again. Being double skinned meant I had to do it in stages to avoid distortion. Once near completion I used a laser to check for alignment and tweaked the frame before finally finishing the welding.
sky.fred
Re: C72 from France
Post by sky.fred » Wed Feb 28, 2024 12:17 pm
My frame is much less damaged, the repairs have been done but it's not very aesthetic and needs to be repaired.
I've tackled the engine overhaul.
I opened the oil pump. No worries. I cleaned it and put in a new internal gasket.
I also dismantled the centrifugal cleaner. It was relatively clean.
Two parts are missing: 24 (pin oil filter) and 25 (washer filter).
Do you know the thickness of this washer?
