Plug caps
casamere
Plug caps
Post by casamere » Mon Aug 16, 2021 11:31 am
Should I be using non resistor plug caps on my CA77 for a better spark.
Tim Allman
Re: Plug caps
Post by Tim Allman » Thu Aug 19, 2021 3:29 pm
I would say yes simply because there is nothing on the bike that will be affected by radio interference. As well, the ignition systems on these machines are a bit weak and the resistor will lower the spark voltage a bit. Be sure that the plug wires are in fact, wires. I've found that the resistive glass fibre and carbon leads that are commonly used in cars are a maintenance headache. Because they are resistive, they will also lower spark voltage.
I found this article a while ago and think it worth a read.
https://motorcycleproject.com/text/plugwiretech.html
casamere
Re: Plug caps
Post by casamere » Thu Aug 19, 2021 4:09 pm
Thank you for your impressive response Tim.
ELMST616
Re: Plug caps
Post by ELMST616 » Fri Aug 20, 2021 10:49 pm
I recently upgraded to an electronic ignition system with new coils and caps, new rectifier and of course the new electronic ignition. Vastly improved the performance. Starts right up and runs very smooth.
There are several electronic ignition kits out there. I used the one from Charlies Place which I am very happy with. Throughout my install I had a few questions and to my great surprise Charlie responded to my emails within minutes to provide some assistance.
casamere
Re: Plug caps
Post by casamere » Sun Aug 22, 2021 1:21 pm
When the original coil and points on my CA77 start to fail I will have no hesitation in installing an electronic kit. It may not be original but it will give better performance and peace of mind....and no more points.
Tim Allman
Re: Plug caps
Post by Tim Allman » Sun Aug 22, 2021 2:55 pm
Getting back to the thread, these more advanced ignition systems should support resistor plugs and wires. Does the manufacturer say anything about this?
