Eliminate heel toe shift lever
Eliminate heel toe shift leverHey all,
I'd like to get rid of the heel/toe shift lever on the dream - it gets in the way...a lot... I don't want to cut this one up - I'll just throw it in the box of extra parts for the next owner Anyone know what other "regular" lever will slide onto the splines ? Thanks ! Dan Gear shifter.I think the gear change shaft on your bike is pretty well a Japanese standard sized spline, if so there will be plenty of levers which will fit.
Why not have a walk round a bike breakers yard and pick up a few that look something like then see which you can 'fine tune' to your requirements. What do you have against the standard toe and heel arrangement? My first bike was a C92 Benly which also had a toe and heel pedal, don't remember it being a problem although, as it was my first bike' I didn't have experience with anything else (until I bought my first CB77) This was a looonnng time ago!
Re: Gear shifter.Big feet and the way I position my feet on the pegs... It's a personal preference thang...
Re: Eliminate heel toe shift leverCL72/77 Scrambler lever?. ...........lm
