Cl77 Crank shaft
CL crankHello Mike
Graham has answered the questions, unfortunately I am a bit away from Norfolk, near Edinburgh. If you don't want to fit a new end to what you have I will see what I have. Gordon Re: CL crankI can probably find you a fresh crank end and fit it for you if your Engineering shop cannot help.
I got the crank yesterday afternoon and pulled off the generator side web. The big end cage looked a bit horrible and one or two rollers were damaged but the rod and big end pin looked fine.
I didn't have a CL77 generator-side web so I used a CB77 part and blocked off the oil hole. Having done that side I decided that I couldn't leave the other side of the crank untouched. The other big end had the same nasty-looking wear on the cage but the rollers looked fine. In went another fresh cage after a good clean up. Everything went back nicely and trued up without any drama. It should do the job for the forseeable future. G '60 C77 '60 C72 '62 C72 Dream '63 CL72
Re: Cl77 Crank shaftHaven't been here much since the spam, I have removed several taps and broken bolts over the years with a plasma cutter, pretty much washes the the bolt out with damaging the threads. The tap you just cut through the center. Dick Dick Johnson
'61 CB92 '63 domestic CL72 Type 2 '63 CL72 '65 CL77 '66 CB77 '67 CB450D '71 SL350 '71 XS1B Please do NOT go anywhere near it with a plasma cutter, you could easily wreck it. I have been in the fabrication industry all my life and have many years experience with these machines and would not attempt it on one of my cranks.
I suggest you go to you tube and look at methods of broken tap removal. Hope this helps, Al.
