This should be an easy one for you.
When my CA77 is running it sounds great no unusual noises.
But when I switch it off just as is stops there is a clonk as if something is dropping inside the motor. Its not loud and it dosnt do it very time. I have herd the same noise on other Honda engines I had a 600 silverwing with the same noise.
Is it anything to do with the starter clutch.
play name the clonkplay name the clonkif its not broke don't fix it.
Aermacchi ss350 Gilera 124 James SC1 Scooter Honda CA77 It's the hamsters plopping down on the bench!! I jest. Offhand guess, crank might be finishing running through a rotation (360 crank?) and the compression from the power cylinder is forcing it down. LM will have a better answer I'm sure. I'm just guessing from my attempts of timing before realizing no plugs makes it easier to do.
