aluminum cleaner
Guest
aluminum cleaner
Post by Guest » Fri Jan 21, 2005 10:22 pm
ok, motor done.<br /><br />but of course i need a little bit of help.<br /><br />see, i did a really great job of taking stuff apart, even put sets of parts with the bolts in labeled plastic bags. i ended up taking some of the pieces to my mechanic, when i realized i would need wrist pins cut down on a lathe to fit. (they needed to be a bit shorter)<br /><br />he ended up putting the whole motor together. all new seals, rebored 1 size from the machine shop, the internals are absolutely fabulous. he thought the transmission looked as good as new.<br /><br />but i took him the parts over 2 days.<br /><br />the problem was he beaded the jugs (cylinders) before i took him the head. after he looked at the cam and decided not to disassemble the head, he could not bead blast it.<br /><br />well, let me just say the motor looks like a zebra. i keep waiting for the flies in the commercial for &quot;Racing Stripes&quot;, the movie with the Zebra. the flies dance back and forth over the stripes singing &quot;Ebony and Ivory&quot;<br /><br />as i cried to my wife, i made her run out and look at it in the back of the SUV. her only comment cut to the bone, &quot;It doesn't look like the ones we see on TV&quot;.<br /><br />well, the mechanic said to get some mag wheel cleaner, seal off the intake and exhaust and they would all clean up decent.<br /><br />unbeknownest to the mechanic, before now i used; oven cleaner, comet as a paste, mean green, lime away (i actually had that recommended highly on the S-brand 2-stroke site) and some other kind of cleaner called &quot;the works&quot;, all on the bottom end while the cylinders were at the machine shop.<br /><br />at best they are a lovely shade of dirty.<br /><br />as i showed my scepticism, the mechanic tried to explain that truckers use a mag wheel cleaner on their aluminum gas tanks that takes off the road dirt and really makes them shine.<br /><br />as i am open to anything i ran down to the auto parts store. well, it is new. ah worse, it is staffed by 2 kids that don't look to be my age between them. <br /><br />worse, they are twice as long winded. well, ok, not if you don't count the &quot;uh's&quot; and &quot;um's&quot;.<br /><br />basically, they don't have a clue.<br /><br />so, after the story of my life; what is the most powerful acidic, oil disolving, deep cleaning thing under the sun to use on a fully assembled motor??<br />
Guest
Re: aluminum cleaner
Post by Guest » Fri Jan 21, 2005 10:30 pm
oh, and i just realized the reason i am asking is that i don't have a clue either.
Guest
Post by Guest » Fri Jan 21, 2005 11:39 pm
and i forgot to mention the paint stripper.<br /><br />i have hit the side covers with everything i could think of. what is the magic?<br />
georGe
Post by georGe » Sun Jan 23, 2005 10:10 pm
Im still tryin to figure out why the wrist pins needed to be cut ?<br /><br />Carb cleaner ! If that doesnt work yer pretty much stuck as only blasting it will get the job done.<br /><br />As fer the parts store fellas most of em are morons no matter what age they are. I can handle the younger ones easier than the older ones. They think because they're older than me they know more. Amateurs !!<br /><br />georGe
Guest
Post by Guest » Mon Jan 24, 2005 12:52 am
well Gman, the parts he could order new did not include absolutely correct length wrist pins.<br /><br />as they did not come with the pistons i bought off of evilbay and ohio cycle does not list them as available<br /><br />http://ohiocycle.com/catalog2.html<br /><br />we ordered the correct diameter and trimmed off 3mm in a lathe.<br /><br />i need to finish making some temporary covers for the intake and exhaust, then i will report what i use and results. i have a digital camera and will get some pics so it is understood what i am talking about.
georGe
Post by georGe » Mon Jan 24, 2005 6:20 pm
I got ya on the wrist pins, glad it worked out !<br /><br />I think I know what yer talkin about w/ the rest,if ya have to blast it use walnut or baking soda as a media. If ya go w/ the later use a good mask as it is not good for the lungs.<br />Good luck I dont envy ya one iota !<br /><br />georGe
Guest
Post by Guest » Tue Jan 25, 2005 12:50 am
we are going to try a lot of chemicals first and post results.<br /><br />i have a small outdoor sandblaster that while it has multiple tip sizes does not have a reclamation apparatus. the walnut shells seem to be $50 for a 50lb bag not including shipping. (regular blast sand is about $11 per 40lbs) aside from the health risks, blasting is not easy or fun work.<br /><br />i would rather spray on $25 worth of stuff, drink a beer, and hose it off than i would to wear that hood, gloves and mask; then lose it all with no way to reclaim it.
