mystery motor part please help
malcolmgb
Post by malcolmgb » Sat Mar 15, 2014 6:48 pm
Just a thought is it the plunger in the clutch basket that pushes against the left engine cover? hope my description makes sense.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Post by LOUD MOUSE » Sat Mar 15, 2014 6:54 pm
No. ......................lm
malcolmgb wrote:Just a thought is it the plunger in the clutch basket that pushes against the left engine cover? hope my description makes sense.
tom0811
Post by tom0811 » Wed Mar 19, 2014 7:28 pm
Thank you, It fits perfectly in the oil filter.
Post by LOUD MOUSE » Wed Mar 19, 2014 7:41 pm
Good deal but it doesn't look like any of the OEM HONDA parts that I have for that application. ..........lm
tom0811 wrote:Thank you, It fits perfectly in the oil filter.
Post by LOUD MOUSE » Wed Mar 19, 2014 8:15 pm
Where did you put the washer on the shaft?. .........lm
tom0811
Post by tom0811 » Sun Apr 20, 2014 1:53 pm
just got side cases back from painter and the inspection covers from polisher. I will post pics soon. I still cant figure out what the pin is for or if it belongs in the oil pump shaft. Is is a check valve? Are there more parts missing like a spring and ball? I have not been able to find it on any parts breakdowns that I can find. Thanks It definitely came out of this motor which is a CA77
tom0811
Post by tom0811 » Mon Apr 21, 2014 4:09 pm
The pin is not the retainer for the oil filter. When I said it fits in the shaft, I meant that the od of the pin fits the id of the shaft. The thrust washer and pin are in place. The pin also fits perfectly in the end of the transmission output shaft on the right side of the motor(where the chain sprocket is) Could this be the home for my mystery pin?
