Trying to free a stuck engine
56_oval
Post by 56_oval » Tue Feb 22, 2011 12:47 am
miles2912 wrote:
NHRalph wrote:Thanks everyone. I decided to take your advice and rebuild the motor. I took the engine out and getting it ready for the bench. While waiting for parts, I'll sand down the frame and re-paint.
What parts are you going to order? I will have to get (obviously) replacement gaskets. A complete replacement screw set would be nice too.
Are you planning on a rebuild as well? If so, go ahead and order the 14mm bushing that the kickstart gear rides on. ( http://www.classichondarestoration.com/ ... od_66.html ). I've torn down two engines so far and found both bad. Gaskets of course, seals also. You'll want to inspect your cam chain followers to see what shape their in. I believe that's about it, unless you're going for an exstensive rebuild including valves and such...
Oh there's a guy on ebay that sells stainless cover screws, just know that the set does not include EVERY screw, but most. The price is great for what ya get.
brewsky
Post by brewsky » Tue Feb 22, 2011 5:37 am
Is this the screw set you are referring to?
http://www.rimfire-eng.com/CB77_Ordering_Page.htm
56_oval
Post by 56_oval » Tue Feb 22, 2011 11:35 am
brewsky wrote:Is this the screw set you are referring to?
No, it was this one.
http://cgi.ebay.com/ebaymotors/Stainles ... ccessories
roadcapDen
Post by roadcapDen » Tue Feb 22, 2011 2:49 pm
FYI - Mine were soaking in various penetrants for almost 2 months and NO movement.
I fab'd a puller/pusher out of 1/4" steel plate to try and get the pistons to move.
Drilled 4 holes to go over the studs then used sockets to put on top of the pistons and crank down the nuts over the stud bolts.
After 3 days alternating between pistons finally have them moved down (actually the cylinder is moving up) approx an inch! took a lot of work to get this far, hopefully another few days and they will be free.
soaking, cranking and pounding...
roadcapDen
2 HD XL's
65 Dream 305
and a bunch of other scoots
