Starter motor chain length?
Geoff Hastings
Post by Geoff Hastings » Sun Mar 05, 2017 12:35 pm
Another question for you guys, I'm assembling a 1964 305 engine. When I bought the bike the starter clutch had disintergrated and had no chain on it when I stripped the engine. I managed to get another starter clutch off eBay but when I came to fit the new chain and the starter motor the chain seems far too tight. I had a spare starter and that gives the same result, everything is in line and the chain sits on the sprocket ok.
Ok, forget that question there was a burr on the back of the sprag clutch sprocket that stopped the chain seating fully. I should have looked more closely before fitting a second hand part.
dragonfly888
Post by dragonfly888 » Thu Mar 30, 2017 11:23 am
Good that you solved your problem !
I just replaced my starter with a used part (1966 CB77) and the chain seems very loose. The bike starts and all, but I am wondering how taut the chain is supposed to be ?
Thanks!
_________________
1966 CP77 305 Super Hawk
Burlington, Ontario Canada
Geoff Hastings
Post by Geoff Hastings » Thu Mar 30, 2017 11:41 am
dragonfly888 wrote:Good that you solved your problem !
Thanks!
As you might guess from my post my new chain has only a little slack in it. Probably only about 10mm at most, check your sprag clutch does not have excess play in the bush where it runs on the crank.
dragonfly888
Post by dragonfly888 » Thu Mar 30, 2017 11:47 am
Will check it. Thanks, Geoff!
_________________
