Exhaust leaking from kickstart engine case
Exhaust leaking from kickstart engine caseThere seems to be exhaust leaking from the engine case behind the front sprocket. I haven't had the engine running with the case off to see where it's coming from. Is this a common issue?
Re: Exhaust leaking from kickstart engine caseIf your engine has the breather tube from the top installed under the engine center cover what you see may be case pressure being exited there.
What engine work have you done?. ..............lm
Got it.
Actually nothing should show from that tube unless it has tired rings or the top of the engine installed with the gaskets (2, one metal and one fiber) installed wrong. ......................lm
