tach cable seal?
eyhonda
tach cable seal?
Post by eyhonda » Sun Oct 17, 2010 10:38 pm
does anyone have a part number for the tach cable seal? mine is missing the seal and leaks. or does anyone have one to sell? the parts catalog doesnt show one.
63 cb77 cafe
www.eyhonda.com
mobilyte
Post by mobilyte » Mon Oct 18, 2010 2:01 pm
are you referring to the o-ring (#26 in the diagram) or the bushing inside the cable itself?
Re: tach cable seal?
Post by LOUD MOUSE » Mon Oct 18, 2010 2:04 pm
The seal at the tach cable end was/is part of the cable and not available as a separate part. ......lm
eyhonda wrote:does anyone have a part number for the tach cable seal? mine is missing the seal and leaks. or does anyone have one to sell? the parts catalog doesnt show one.
eyhonda
Post by eyhonda » Mon Oct 18, 2010 2:33 pm
I'm looking for the seal in the cable itself. Does anyone have a spare or can someone measure their part so I can try to find a close alternative?
63 cb77 cafe
www.eyhonda.com
eyhonda
Post by eyhonda » Wed Oct 27, 2010 9:39 pm
I found a neoprene washer at the hardware store that was just a little bigger diameter. No more leaks!
63 cb77 cafe
www.eyhonda.com
mobilyte
Post by mobilyte » Fri Oct 29, 2010 5:48 pm
curious...are you using an oem or aftermarket tach cable?
eyhonda
Post by eyhonda » Fri Oct 29, 2010 7:15 pm
aftermarket. I dont remember seeing any seal before. it was either missing or it popped off during disassembly. then it grew legs and ran off! now it seems I have another slight leak at the left exhaust port. it might be a leaking valve seal. the plugs are dry.
63 cb77 cafe
www.eyhonda.com
