Question on 305 headsQuestion on 305 headsIs a CL77 cylinder head interchangeable with CB77?
Thanks, Kurt studs will need to be a different lenght for the cl head vrs the cb head. the heads are different heights in different areas, so the studs are cut for the particular usage. you can change the studs out as well as the head. Also remember the acorn head Nuts do not allow for long studs sticking through the head, unless you add lots of washers. And on the short studs???
two cl77, three cb77, ca77, ca72, cb160, s65 and cb750
Help Stop Global Whinning Its considered bad luck to be superstitious.
