electric start on dream
electric start on dreamI get the starter clutch out and apart and do not understand why those little plungers are there, I thought springs would be behind them but no, so what is their purpose, I understand the rollers and ramp operation with the rollers engaging the clutch and runway on the starter sprocket, seems like that is all you need and the plungers do nothing, any thoughts?
There are small springs that go under the plungers. Very fine wire! They seem to disappear, kind of like one sock of a pair in the dryer. If you have the starter clutch apart now, replace the plungers,springs and rollers. Check the flat head screws that hold the backplate to the assembly, they crack and or loosen up. Restake the heads of these screws if necessary. Check the face of the starter sprocket where the rollers ramp up to for galling or loss of hardface.
that makes more sensewhat through me off was that there was NO sign of any springs, completely disintergrated apparently, very dry in there as well, now I have to take the sprocket out and clean the roller surface and I think I'll finish it by buffing it. Do they recommend grease in there after reassembly?
starter clutch greasei've been using a moly-based silicone grease to lube my starter clutch- just a very small amount seems to work just fine. (i put on the spring end caps along with any areas that slide or move.- bk
Don't get that problem now that she's left; I have correct pairs again!!
Re: starter clutch greaseThat's what I was gonna do, but LM says to leave the whole sheboodle dry otherwise it's likely to pick up dust & crap.
