Honda C200
Almost ready to go...I got most of the bike's loose ends buttoned up and I am ready to start up the motor. Combustion, spark, battery, key turned on... check.
Now, I wish I knew which position the little slider on the left side should be in. Does anyone know what these positions are for? Headlight? Engine kill?
Starting Tips NeededDoes anyone have any tips for gettings the settings right for startup? I totally dissasembled the carb and don't know where the fuel/air and idle screw settings should be.
Does anyone have some pointers for a sucessful start after an engine and carb rebuild?
Yes... a giant "THANK YOU" is in order for all the info Paul has shared. He has been a great resource in getting this old bike apart and back together. There really is no info out there on the C200 model and this forum has been a nice depot for information on this motorbike. I truly appreciate his time and insight on the C200 project.
singapore c201after following your post for awhile..yr project inspires me to do up mine.. here's the stuff i did till now.. :)
before reading your excellent restoration.. :) When i got the bike, the entire front section belongs to a Honda S90.. search all ard the world n luck was on my side..manage to get hold of the entire front from ebay n asia.. Here's what happens after reading seeing your project.. :) Here's the color i'm trying to achieve. Here's the rest of the bike as of now.. :) Check out the background of this pix.. i stick your beautifully rebuild C200 on the wall for inspirations.. That's it for now..will update you once i've completed the project.. Cya..
