Engine drive chain sprocket
Bought anything recently? Liked it? Hated it? Post your review...
Dream two
Post by Dream two » Wed Aug 05, 2015 12:01 am
Cleaning engine (on bench) inside right cover I noticed that my sprocket was kinda loose.
It was held on by a lock washer fastened with 2 bolts into the sprocket.
I undid these bolts and removed the sprocket, there appears to be nothing that can tighten up sprocket. Now I can't line up lock washer and replace sprocket, Anyone??
Thank you in advance.
1964 CA 77
Dream two,
LI NY
OldStan
Post by OldStan » Wed Aug 05, 2015 6:10 pm
1.Slip the sprocket on shaft.
2. Slip the lock on the shaft until it is in line with the groove.
3. THEN turn the lock into the groove to line up the hole in the lock to the sprocket.
4. Install bolts.
63 CA78
Dream two
Post by Dream two » Fri Aug 07, 2015 8:44 am
Figured it out in the meantime. So the lockwasher stops it from sliding of the splines. Now it is still loose. Can slide side ways a bit. This is to make sure the sprocket always lines up with the rear sprocket? If that's the case than this is the first time I've seen that. Cool.
tech54K
Post by tech54K » Tue Oct 24, 2017 10:56 pm
this thread is really helpful.
