1969 honda 305 (locked up motor)1969 honda 305 (locked up motor)I have a buddies 305 engine sitting on my shop table (he stated it's locked up), but it looks great.. .any chance we have a transmission issue? Where to start?
Sorry for the delay. I have a newborn and time is scarce. Just started on it again.
I can turn the sprocket in nuetral, but can't in gear. When in gear, I can pull the clutch lever, and can't turn it either, which I thought was odd. I'm having issue removing the transmission side of the case cover, due to the phillips screws being 50% soft, and 50% frozen. I can use a screw extratcor, but does anyone have a source for the kit of screws? That said, when in nuetral, it should still kick over, and after a healthy dose of penetrating oil and tons of time, it still seems bound up. Could a clutch issue, which probably exists, be the culprit?
