Handle bar removal on Dream and left side controls
bbap
Post by bbap » Thu Jul 14, 2011 9:39 am
Has anyone had recent experience removing their handlebars from a late Dream 305? I've gotta replace my bars and the left side controls where the wire comes through the bars and attaches to both the horn and high/low beam is holding me fast.
Is it easier to remove the front headlight and bar clamps and push out some slack and disconnect the controls or is their an easier way?
As always, thanks much!
Steve
CA78 - 3111XX - Frame
CA77E - 3161XX - Engine
Hahnda
Post by Hahnda » Thu Jul 14, 2011 4:38 pm
I would start with unhooking the wiring in the headlight shell for the controls. Then remove the bars from the bike. Then remove the controls from the bars. The old wiring is going to be pretty stiff so it probably wont be all that easy to get out.
brewsky
Post by brewsky » Thu Jul 14, 2011 4:51 pm
Hahnda wrote:I would start with unhooking the wiring in the headlight shell for the controls. Then remove the bars from the bike. Then remove the controls from the bars. The old wiring is going to be pretty stiff so it probably wont be all that easy to get out.
Ditto to that!
The wires are soldered to the contact plates in the switch and don't like to come out toward the bottom of the bars.
You could blow some hot air from a hair dryer or the like in the end of the bars to try and soften up the wires, and shoot some WD40 in there also to try to prevent skinning the insulation when removing.
bbap
Post by bbap » Thu Jul 14, 2011 6:54 pm
Thanks Guys, I removed the wiring in the headlamp and used some spray silicone. Came out like a dream...Thx!
milwaukeephil
Post by milwaukeephil » Wed Jul 20, 2011 2:56 pm
Did you have to do some milling on the new bars or did you find some with the slot?
bbap
Post by bbap » Thu Jul 21, 2011 7:08 am
I don't have access to a Mill, so I used a dremel and went very, very slow. So far so good. Just waiting on a small part to put her back together. A Mill is the way to go, though.
