hey narly, that black on the heat sink is likley anodized. it wont conduct. be sure to check it if it maters in your setup. just sayinNarly9999 wrote:OK the two wires from the ac stator. Does it matter which side of this rectifier they go to? And why dosn't the third wire from the stator go to the rectifier? That dosen't seem right. WHy?
Also, I used a computer heat sink with some sink greese and added a 12v ball berring mini fan. =-) lol Drilled the center of the heat sink for the mounting screw for the retifier. Haven't fully mounted the unit securely to the frame as yet but plan on something that's astheticly pleasing. The fan and sink are factory black like the bike so it looks pretty good.
I'm only getting 12.23v +/- .5v When the bike is on it has less voltage then when I turn it off. ON it's as said above and when off it climbs to 12.40 +. Any possible reason for this? It was exactly the same before I switched out the Rectifier. So I don't think it was my rectifier causing this issue. Hmmmmm<<<<,
Thanks ! ;)
Selenium Retifier Replacement with Solid State RectifierRe: Does it matter?need RadioShack Part numberHi Can you please advise RadioShack Part number, Thanks
RadioShack P/N 276-1185 called "Full-Wave Bridge Rectifier". 25amps - 50volts
I just finished a minute ago, putting one on my 305 Dream. I mounted it to the original mounting bracket and used #10 stranded wire. I was not able to put a heat sink beyond the mounting bracket the way I set it up. I let it idle for about 10 minutes with lights on and it was getting on the warm side. I may modify my set up a little more as I'm just not sure enough cooling gets into the right side box. Steve CA78 - 3111XX - Frame
CA77E - 3161XX - Engine
rectifier - regulator for cb 77Hei there . . .
I have a modern bosh regulator i want to install in my CB77 on the regulator there are 3 conectors : (-) (+) ( F ) Does anyone have a clue which collors go where ?? Thanks ... M. : )
