Late model headlight
seed
Post by seed » Sat May 01, 2010 12:36 am
Hello everyone,
I just ordered a headlight for my 1967 CP77 from ebay. Turns out it doesn't fit. My headlight uses screws to be secured not springs/clips. There is also an adjustment screw on the bottom of my headlight. Does anyone here know what the part # is for my headlight or if it's compatible with any other models. I'm not sure if this helps but my headlight also has a pilot light.
Thanks and regards,
Seed
Post by davomoto » Sat May 01, 2010 9:36 am
Nor sure of the part number. My 67 CL77 uses the same set up. I tied matching it up with a CB350 headlight, just different enough to not work. I think you'll have to find one from a 67 CB or CL.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
seed
Post by seed » Sat May 01, 2010 5:24 pm
Ok thanks Davomoto! I have a feeling that headlight was used on other models as well. Just not sure which ones.
Seed
Post by davomoto » Sat May 01, 2010 7:12 pm
Let me know if you figure out which other models! Try Nich at Ohio Cycles for a replacement.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
seed
Post by seed » Wed May 05, 2010 12:36 am
No luck yet. Still trying though.
Seed
jensen
Post by jensen » Wed May 05, 2010 2:32 am
Try the headlight from a CB400F, same part number, and it fit's my CB72 '67.
Post by G-Man » Wed May 05, 2010 8:56 am
That's good to know. I managed to cram a Hell H4 halogen reflector into my CB400F headlamp. Had to cut a hole in the plastic headlamp shell to let the pilot bulb holder poke through though....
My CB400F also ran a Lucas 3 phase rectifier when I found out that it cost about 1/4 the price of a new Honda one. I did 14,000 miles on my bike in the first year. Pretty reliable apart from burned-out rectifier, arcing (in the wet) plug leads and rusty front fork stanchions. Those were the days!
About 1978
About 1978
