Tail light wiring
KentuckyDream
Tail light wiring
Post by KentuckyDream » Mon Jul 28, 2008 8:49 pm
Recently replaced the tail light bulb and assembly. Now when I hit the rear break, it blows the main fuse. Do you think I have the wires crossed, or is it not grounded properly?
kustommusic
Post by kustommusic » Mon Jul 28, 2008 10:37 pm
KD, Somewhere you have the brake light wire touching a ground, although I have seen a faulty bulb short the filiment to ground inside the bulb,but that is real rare. Check your wiring from the brake light switch to the bulb you should find it,Good Luck. Kustommusic
KentuckyDream
Post by KentuckyDream » Sun Aug 10, 2008 12:15 pm
kustommusic wrote:KD, Somewhere you have the brake light wire touching a ground, although I have seen a faulty bulb short the filiment to ground inside the bulb,but that is real rare. Check your wiring from the brake light switch to the bulb you should find it,Good Luck. Kustommusic
You nailed it. Rechecked all of the wiring, found where it was grounding out. Rewired, now it works perfectly. Thanks a bunch.
kustommusic
Post by kustommusic » Sun Aug 10, 2008 2:14 pm
Kentuc, Glad to have helped ! Kustommusic
