restoring old boltsYou're welcome, GG. Glad it worked for you!
I use zinc sheet for my anodes and when I have to plate inside a hole I cut a narrow strip of zinc and roll it into a really tight but long spiral that Ican fit into the hole without it shorting out. It's a bit tricky to position but it does get the job done. Wilf Plating inside holesHey Wilf - I would NEVER have thought of that. Fantastic idea. Thanks!
GG
electroplatingI have been wanting to try this for a long time. It has been a long winter and I have run out of projects to do. Got all the fixin's this morning and getting ready to set it up. Thank you guys for showing me how it is done....... mike
66 CL77
CL100 2 -CB125s ATC200
electroplatingI took 1 qt. of vinegar 1/4 lb. Epson salts,1/4 lb. sugar. Shook it up until everything dissolved
No water... it all seemed to do what it was suppose to do. 66 CL77
ok, so this is what i ended up doing,
i doubled the batch of ingredients suggested by Wilf, and added about a gallon of water. I used five zinc strips, and my power source was a 6v 350Milliamp wall charger. i let the bolt sit in the plater for about 15 minutes, then took it out and wire wheeled the grey gunk off, then i plated it again or about 20 minutes. It worked pretty well! now i need to figure out how to do a big batch of a lot of bolts. photo 1 (3) by hill hudson, on Flickr photo 3 (3) by hill hudson, on Flickr photo 2 (3) by hill hudson, on Flickr '65 s90
'64 ca95 dream '65 cb160 '66 cb77
