Wheel Bearings...
Wheel Bearings...Hello all: Just wondering if there is any special trick to removing the front & rear wheel bearings from the hubs? I removed the 3 phillips screws and the stamped steel plate, should they now just fall out or do I have to use some sort of puller? Machine is a "64" CB77.
Thanx, Carl Rear Wheel Bearing SealsNo, they are no longer available.
