Need help ID bike
WRBerg
Need help ID bike
Post by WRBerg » Tue May 08, 2018 4:04 pm
Title says 1966 Honda 305 Dream. Engine stamp says CA77E 1022792. Frame stamp says 1022782. Is this actually a 66?
stevesearles
Need help identifying what year these dreams are.
Post by stevesearles » Fri May 25, 2018 8:28 pm
Crickets.?? WRBerg got no response. I will try. Can anyone help, mine is CA78-1009998.
My CA160 is CA160-1012219. Where is this information stored for review??? Need to know what year to get a title. Any info would be appreciated.
Re: Need help identifying what year these dreams are.
Post by G-Man » Sat May 26, 2018 12:06 am
If you look at the wiring harness under the gas tank (maybe inside the frame) you will see a little white tag which records the date of manufacture date of the wiring harness. Bike date will be slightly later than that.
7-digit frame numbers are all late '64 onward and Honda did not split the sequence into years from then on so you have to do a little research. Luckily e3Steve has done that for us in the form of this list.
Talk about Crickets! You have been a member since 2008 and only made 9 posts.... :-)
These are CB77 numbers but the CA78 may be similar....
As for the CA160, this is the forum forum 250 & 305 owners so that will be somewhere else.
1001184 - '65, ('64 harness)
1004539 - '65
1013505 mine - '65
1013558 - '65 harness
1013774 - '65 reg (US)
1021946 - '65 harness
1022392 -
1025797 -
1028xxx - '66 reg (US)
1030728 - '65 harness
1032915 - '65 harness
1035519 -
1038282 - '65 harness
1038331 -
1038335 - '65 harness
1039003 - '65 harness
1043961 - '66 harness
1049722 - '66 reg (US)
1053051 - '67
1055763 - '67
Honda published a list of numbers in the Parts manual for each bike. If you don't have a manual - it is a good idea to get one.
you will see a little white tag which records the date of manufacture of the harness
stevesearles wrote:Crickets.?? WRBerg got no response. I will try. Can anyone help, mine is CA78-1009998.
