Sprockets?
willy_j
Sprockets?
Post by willy_j » Thu Apr 30, 2015 5:08 pm
I recently found out through a relative of mine of a machine shop locally located in Wisconsin that may be able to do small production runs on sprockets for our bike. When I asked them about making a sprocket using an original, they pointed me towards possibly using the front sprocket from a Virago 250. Pictures make it look like they are the same for tooth count, shaft shape, and bolt location, but they are a 520 pitch. http://www.ebay.com/itm/16-Tooth-Drive- ... 40&vxp=mtr
When I decided to look up the rear sprocket, the smallest that I saw was a 38 tooth rear. It may be false memory on my part, but wasn't the stock size on the rear a 31 tooth? And does anyone have the center to center measurement of the bolt holes going across the middle? One Ebay listing says 145mm center to center. http://www.ebay.com/itm/JT-520-Steel-38 ... fresh=true
What does everyone think of this?
hotrodhendrix
Post by hotrodhendrix » Fri May 01, 2015 7:30 am
I don't remember the counts but 250 and 305 dreams had different rear sprockets. When building mine I considered having one made also but ended up just getting a stock style aftermarket from Ohio cycle
