Some pics of the old girl and a carb question
maybe368
Post by maybe368 » Wed Apr 13, 2011 6:07 pm
Here are a few pics:
right side by maybe368, on Flickr
right rear by maybe368, on Flickr
right front by maybe368, on Flickr
left front by maybe368, on Flickr
stripped by maybe368, on Flickr
welsed by maybe368, on Flickr
I have the timing and points set and she starts right up, She is running lean, because if I choke it a bit, she purrs like a kitten. When I rebuilt the carb, I reused the old jets and metering pin. I used the idle adjusters from the kit. Any suggestions? I adjusted the float to 26.5 mms from the gasket surface. Thanks in advance...Mark
You didn't stop running because you got old, you got old because you stopped running
pknopp
Post by pknopp » Wed Apr 13, 2011 6:57 pm
Are the pipes still open? Sounds like you are off just a wee bit. Could be the short straight pipes if that's what you are still using.
maybe368
Post by maybe368 » Wed Apr 13, 2011 7:00 pm
pknopp wrote:Are the pipes still open? Sounds like you are off just a wee bit. Could be the short straight pipes if that's what you are still using.
I am not sure what you mean by pipes. Can you elaborate for a dummy?...Mark
pknopp
Post by pknopp » Wed Apr 13, 2011 7:41 pm
Sorry, your exhaust. Do you have the mufflers on or are you just running the header pipes?
maybe368
Post by maybe368 » Wed Apr 13, 2011 7:47 pm
pknopp wrote:Sorry, your exhaust. Do you have the mufflers on or are you just running the header pipes?
That's what I thought. No, I am running complete pipes and baffles. You are right, it is very close. If I barely choke it, it is real smooth. Besides the carb oring, any other potential vacuum leaks? Thanks...Mark
brewsky
Post by brewsky » Thu Apr 14, 2011 4:42 am
There is another O ring between the carb insulator and intake port.
Also, the carb body can become warped from overtightening the mounting screws, a common occurence. If so, that O ring may not seal.
Have you tried richening the idle mix screw? (the one closest to the motor)
maybe368
Post by maybe368 » Thu Apr 14, 2011 9:26 am
brewsky wrote:There is another O ring between the carb insulator and intake port.
Thanks, I'll replace that other oring, The idle mix screw does not seem to have any effect, any ideas or clues from this? Should I put the originals back in. I read in an older thread to not use any of the brass in the kit. Thanks for the help...Mark
