Petcock Screws - Correct Tap size?
Petcock Screws - Correct Tap size?Good evening from Marietta, Ohio. Last night I was installing the popular aftermarket petcock on the bottom of my CA78 gas tank. One of the screws was going in kind of tight so I was screwing it in and out until I got close to having it fully inserted. It got tight and I ended up snapping the head off!
This morning I drilled the screw out of the nut and some of the threads were effected. I'd like to run the proper tap through the nut to try and salvage the threads and was wondering what tap I should use. Also, if that doesn't work, has anyone had to drill and tap the nut slightly bigger and if so, what size did you end up with? Any other ideas? Thanks.
Those are JIS screws. Did you get it fixed?
