The shift drum wears in the slot at the end with the poky thing.
It wears where the point is in the slot and the roller wears on half of its surface.
Forks wear at the pads on the ends and usually will be bad when the wear is about 10th or more.
They don't always wear on both sides of the pads. .....................lm
joeweir1 wrote:Any images of a new fork?I know when I split the cases in an attempt to find the problem I checked the rollers and they did not jump out to me as being worn or damaged to badly.The shift drum seemed ok and no chips or unusual marks .Forks were worn on the face.Only those were a question mark to me.Where is the best source these days for forks and rollers?
