electric starter issue
Hoosier Tom
Post by Hoosier Tom » Sat Jun 11, 2016 3:52 pm
Tusk wrote:Greetings. I am working on this same issue for a friends CA77 Dream. I'm having trouble finding and/or figuring out the size/part number for a magneto puller.
Can someone assist please?
Many thanks!
Mark
I assume you mean the rotor. These bikes don't have magnetos. Use the search function for "rotor puller" and you'll find plenty of info. Good luck.
HT
mike1969
starter
Post by mike1969 » Sat Jun 11, 2016 5:20 pm
I have the correct size bolt that will pull your rotor. $5.00 shipping included. Mike
Post by G-Man » Sun Jun 12, 2016 3:39 am
It's an M16 x 1.5 pitch bolt, I believe.
Tusk
Post by Tusk » Sun Jun 12, 2016 7:15 am
G-Man wrote:It's an M16 x 1.5 pitch bolt, I believe.
That's what I'm looking for. Many Thanks G-Man.
I'm used to working on bikes from the 80s on up. So, apologies for the terminology faux pas. First time on the Dream. It's all Original and unrestored. Not bad but a little rough. Most of it's life was spent near Pittsburgh Penn and the salt had its way with the exhaust and that was replaced.
My friend inherited it from his Father.
Very easy bike to work on though! And more parts are available then for my 88 Honda HawkGT!
Thanks again folks. Off to find the correct tool to get that starter clutch rebuilt! (pm'd ya Mike!)
malcolmgb
Post by malcolmgb » Sun Jun 12, 2016 2:25 pm
I went to an 'Autozone' they had a rack of replacement oil drain plugs, look for the correct thread size.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Tusk
Post by Tusk » Sat Jun 18, 2016 7:17 pm
Thanks to Mike, I got the bolt needed to remove the rotor and did so today. Some pics to assist with anyone having this issue in the future.
Bolt goes in here :)
I had to raise the bike up a bit and brace the rear wheel. The raising part was to get it in gear.
Turn the bolt in just a bit. It didn't take much and it pulls loose. Then just comes off. The little piece came out immediately. Part of the starter clutch assembly.
Back part of the rotor/starter clutch.
Tusk
Post by Tusk » Sat Jun 18, 2016 7:21 pm
I had one out of the three sections in tact.
Remove the three big screws to separate the rotor from the starter clutch.
Then separate. I had used some PB Blaster to help loosen the screws.
Tim from Classic Honda Restoration fulfilled my order quickly! Here's the starter clutch rebuild kit as it arrives from the Post.
