Oil spinner
jbrownmxr
Oil spinner
Post by jbrownmxr » Sun Aug 05, 2012 9:18 pm
I'm in the process of freshening up a 67 dream 305. Neither my o ring kit, nor my seal kit came with the o rings for the oil spinner or the cover. You guys have a line on some (3)?
JB
conbs
Oil spinner o rings
Post by conbs » Sun Aug 05, 2012 10:27 pm
Search this site. I think someone posted SKU numbers for o-rings you can get at a hydraulic shop.
jbrownmxr
Searching
Post by jbrownmxr » Tue Aug 07, 2012 10:38 pm
Search failed to give me answers. If anyone's is I the know, lemme know...
conbs
Oil Slinger o-rings
Post by conbs » Tue Aug 07, 2012 11:21 pm
http://www.honda305.com/forums/motors-2 ... cc-f8.html
No SKU numbers, but a path forward.
Edit: I guess that link doesn't work as I intended. Take your slinger and o-rings to a hydraulic shop. They should be able to help you.
OldStan
Post by OldStan » Wed Aug 08, 2012 9:13 am
I got my o/r for the filter from Ohio Cycle- but with an order of other parts, he has a $20 minimum. He also has the cover o/r's. Beware though, there are at least two different covers. Mine has the early which has 2 of the 57x3 mm o/r's which are available at seal suppliers, being a fairly common size (Ohio has them too.) The later ones are larger and I think they have them as well. A couple of different sizes show on the parts list, so the best thing to do is measure either the old o/r's or the bores and that should get you close enough to choose which ones you need. I picked up an extra set for mine since this is an area that is accessed fairly regularly. That way if I damage a seal I don't have to wait for a replacement.
63 CA78
