Chroming the front suspension unit on a Dream.... Thoughts?
wombat200
Post by wombat200 » Sat Sep 18, 2010 6:42 am
Hi All,
The pivoting arm/loop on my Dream (that forms the leading link suspension & holds both shocks) needs chroming.
Thing is, I'm unsure what to do aboutn the bakelite bushes on the pivot-points. Sure, the steel bushes slide out, but they leave a bakelite-type sleeve behind, which probably won't press out without destroying it.
What have others done here? I'm guessing the only real solution is turn up some bronze bushes & press them in......?
Thanks!
Rob.
wombat200
Post by wombat200 » Mon Sep 20, 2010 12:49 am
Anyone??
Post by G-Man » Mon Sep 20, 2010 1:11 am
Rob
I have the same task to do on two dreams. I have not had time to check out the arm but it seems that we would have to make up a tool which would fit the bush but have a step on it so that it will support the bush as it's pressed out.
Plan B would be to make new phosphor bronze bushes, exactly as you say. I'll try and have a look at the parts this morning. I made new bushes in phos bronze for my CL77 forks to replace the aluminum ones so that's probably the best option here.
wombat200
Post by wombat200 » Mon Sep 20, 2010 1:16 am
Thanks G - the bushes themselves appear so thin-walled that I don't think any amount of support will help - I reckon they'll just collapse. I'm going to take one up to a mate of mine with a lathe & the suitable skill & see if he thinks it viable to do in bronze......
Post by G-Man » Mon Sep 20, 2010 1:50 am
Rob
If it can be done in plastic, it will be straightforward in bronze. It's just quite costly as you end up turning most of the material away.
wombat200
Post by wombat200 » Mon Sep 20, 2010 1:58 am
I think I'd be tempted to leave out the steel inner bush & turn up a one-piece bush in bronze......
nc_rider
Post by nc_rider » Mon Sep 20, 2010 7:43 am
If you end up making bronze bushings have your friend make a decent sized run of them and stick them on ebay every couple of weeks. I'll most likely need a set and I'm sure there will be others who need them.
