Road Gearing
Waveblaster
Road Gearing
Post by Waveblaster » Wed Jan 13, 2016 2:17 am
Greetings
I have a CL72 1964 with large rear sprocket (compared to CB77) which may or may not be standard.
I was considering running a 15 tooth front and a 32 back for better street performance. Has anyone run this or similar combination successfully
regards
Greg
SMBH
Post by SMBH » Wed Jan 13, 2016 11:38 am
That is what I have on my 1964 CB77 15 Front 32 Rear and very happy with it.
The STD gearing for the CB77 is 15t 30t but I put a 32 on the rear and I get better mid range performance im not intrested in top speed.
OldStan
Re: Road Gearing
Post by OldStan » Wed Jan 13, 2016 4:47 pm
Waveblaster wrote:Greetings
regards
Greg
I have 15 front and 33 rear on my CL77. I would not recommend this unless your running on flat open spaces. It's a bit too high geared when taking off from a stop and requires a down shift on moderate hills, although I can do 50 mph easily in 3rd gear. I'm leaning toward a 37 on the rear when I change it.
Remember when comparing the CB has on 18 inch wheel and the CL has a 19 inch. That will make a considerable difference in the final speed.
63 CA78
mike in idaho
Post by mike in idaho » Thu Jan 14, 2016 8:05 pm
37 teeth on the rear is standard, pretty good all around gearing. It will go 50 mph, in second gear, with 16/37 gearing. These motors are happiest running at 6000-7000 rpm, when cruising down the highway. It won't go any faster in high gear if you lug the engine with high gears. Back in the late sixties I went on a three day, 1000 mile trip with some friends on my 305 scrambler. I had a 32 tooth sprocket mounted on the back wheel for the trip. I got the same gas mileage as one of my buddies riding a CL77 with standard gearing. He could pass cars at will, mine was a real pig for acceleration, I had to plan ahead just to safely get around slower traffic.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
