Too much valve tapping?
Flashy65
Post by Flashy65 » Sun Feb 17, 2008 10:45 pm
I have adjusted and readjusted my CP77's valves to .004, but it's still tapping a little bit. Is this a problem or just something you deal with? I have CA78 that's a little less noisy.
Post by davomoto » Mon Feb 18, 2008 11:28 am
If the valves are adjusted correctly, the tapping is probably coming from somewhere else. The usual culprit is the piston pins get a little loose in the small ends of the rods, and cause a slight ratlle. Pretty normal, I just live with it.
Flashy65
Post by Flashy65 » Tue Mar 04, 2008 2:57 pm
Thanks for the insight. The problem is not severe, and your explanation makes sense. My CP has some miles on it, but the compression is still OK.
Post by LOUD MOUSE » Tue Mar 04, 2008 4:26 pm
Did you remove all the rocker adjusters and make sure there are no flat spots and they are domed?
The cam sprocket can come loose (4 rivets) from the center and make a noise. ...................lm
Flashy65 wrote:Thanks for the insight. The problem is not severe, and your explanation makes sense. My CP has some miles on it, but the compression is still OK.
Flashy65
Post by Flashy65 » Wed Mar 12, 2008 4:25 pm
I did not take the rockers the entire way out. The cam sprocket issue sounds like it could be serious!
Post by LOUD MOUSE » Wed Mar 12, 2008 7:04 pm
Not the rockers.
Just the screw type adjusters.
Look at the end that touches the valve stem. ...........................lm
Flashy65 wrote:I did not take the rockers the entire way out. The cam sprocket issue sounds like it could be serious!
