Cam Chain CA77 checking if correctly installed.
Eddie46
Post by Eddie46 » Wed Jun 06, 2012 7:25 pm
Can you tell if the cam chain is installed corectly without dropping the engine?
Thanks, Ed
Re: Cam Chain CA77 checking if correctly installed.
Post by LOUD MOUSE » Wed Jun 06, 2012 9:28 pm
Yes ya can.
Call me at 830-895-0654 and I'll tell how simple it is. ..............lm
Eddie46 wrote:Can you tell if the cam chain is installed corectly without dropping the engine?
Thanks, Ed
Eddie46
Post by Eddie46 » Thu Jun 07, 2012 8:02 pm
Thanks ED,
You have a gift. Going to fire it up on Monday. Going out of town to nephew's wedding.
Ed
Post by LOUD MOUSE » Thu Jun 07, 2012 8:04 pm
You are welcome.
Have a good time. ...........lm
Eddie46 wrote:Thanks ED,
Ed
Eddie46
Post by Eddie46 » Tue Jun 12, 2012 7:34 pm
Started engine and oil leaking from head caps. Talked to lm and he told me about the special copper washers. Found 4 copper washers and put them on 4 outer corners and leak really slowed down. Warmed up engine and started to torque caps to 25#, they went so far (18#) approx and heard a pink and the rod is now a spring loaded tortion rod and will no longer tighten. Should I unscrew and add filler washers or what? Thanks for help.
Ed
