coils
Re: coils
Why do you ask?. ..............lm
abert51 wrote:where does one find replacent coils for an old cl77. 1965
coils
my cl seems to be breakng down/misfiring when throttle is opened wide as in calling for more power for climbing hills. Float levels set correctly at 22mm for 26 mm carbs, fuel system clean clean, timing set dynamically with timing light and good. Could be bad or old coils? What are the specs (ohms) for orig coils and what do I replace them with. Ebay shows lots of junky stuff.
Dynatek Coils
Abert51, I replaced my coils last year. I had one side that was DOA and the Dynateks work great. I also got the graphite suppression wires/caps, though I forget if they were the 7MM or 8MM (you would just measure yours). The mounting required modifying things a bit but I got the idea from a CB77 owner here on the forum who pointed me towards the Dynateks. My Cl77 has a big blue spark now and starts great. I have NO stock in the company but JLMS here in Florida sells the kits. JLMSvc@aol.com
The owner is Jenny. I highly recommend these and I see that you didn't get many responses except for Loudmouse who is the guru of this site. Good luck, Tim
blue spark
thanks to LM and other I have nice blue sparks now.
Re: blue spark
You are welcome and have fun riding. .........lm
abert51 wrote:thanks to LM and other I have nice blue sparks now.
- Jims65CA77
Re: blue spark
Just wondering what coil did you go with? OR what did you do to "fix" your problem?abert51 wrote:thanks to LM and other I have nice blue sparks now.
Jim
