Cam Chain CA77 checking if correctly installed.Cam Chain CA77 checking if correctly installed.Can you tell if the cam chain is installed corectly without dropping the engine?
Thanks, Ed
Re: Cam Chain CA77 checking if correctly installed.Yes ya can.
Call me at 830-895-0654 and I'll tell how simple it is. ..............lm
Started engine and oil leaking from head caps. Talked to lm and he told me about the special copper washers. Found 4 copper washers and put them on 4 outer corners and leak really slowed down. Warmed up engine and started to torque caps to 25#, they went so far (18#) approx and heard a pink and the rod is now a spring loaded tortion rod and will no longer tighten. Should I unscrew and add filler washers or what? Thanks for help.
Ed
