Voltage to ignition
Voltage to ignitionWhat is the correct voltage going to the ignition.....is it 12 volts or less....much thanks guys............
Re: Voltage to ignitionThe whole electrical system is a nominal 12V system. However, a fully charged lead-acid cell has a nominal voltage of 2.1V so measuring the voltage on a new fully charged battery will show 6x2.1=12.6V. The charging system should push this up to about 14V in order to keep the battery charged although the CB/CL/C/CA/72/77 systems struggle to do this.
Why do you ask?
Re: Voltage to ignitionThe bike I'm working on had the handle bar wires cut...I had to replace the controls with aftermarket ones....there is a black wire with a red strip forward that shows around 8 volts..the other hot ones are 12 volts. ..I didn't know if that wire was going through a resistor for the points......
Re: Voltage to ignitionWhat year / model bike?
If you’re interested in acquiring reconditioned Honda handlebar controls, please contact me. 1967 CL77 305 Scrambler
Re: Voltage to ignition1964 CB77......
Re: Voltage to ignitionThank you
