CB77 foot peg plates question
JSharpPhoto
Post by JSharpPhoto » Mon Aug 11, 2014 8:29 pm
I noticed something strange on my foot peg / exhaust hanger brackets. The mating surface for the pegs (the three toothed/ indexed threaded holes) is completely flat. As in, lay it face down on sheet of glass and it sits flush. The shifter side, however, isn't. The front two holes are plumb, but the rear mount is bent in towards the swing arm. Not a lot, but maybe 10 degrees?
No cracks or distress on that plate, otherwise. So did my bike fall on that side or was it just sloppy casting?
What's the protocol to slowly bend it back? Or just get my head checked.
Post by G-Man » Tue Aug 12, 2014 1:03 am
It will be bent. You may be able to straighten it. At the very least you need to anneal the bracket before trying.
JSharpPhoto
Post by JSharpPhoto » Tue Aug 12, 2014 6:34 am
G-Man wrote:It will be bent. You may be able to straighten it. At the very least you need to anneal the bracket before trying.
right. thanks.
malcolmgb
Post by malcolmgb » Wed Aug 13, 2014 6:01 pm
Anneal aluminium using soap, it turns black just before the melting point of the metal, do an internet search for details.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
JSharpPhoto
Post by JSharpPhoto » Mon Aug 18, 2014 8:53 am
has anyone ever annealed these plates before? it seems like it might be difficult to anneal something this thick.
Tim Miller
Post by Tim Miller » Mon Aug 18, 2014 10:43 am
JSharpPhoto wrote:has anyone ever annealed these plates before? it seems like it might be difficult to anneal something this thick.
I use a large torch with a rose bud. Clamp bracket in a good vise with soft jaws then heat it up till it moves with some force using a big cresent wrench. Be careful aluminum melts at 1100f. If it cracks vee it out then weld it.
Tim
