speedometer needle removal
markymark2
Post by markymark2 » Mon Apr 05, 2010 9:00 am
do i just pry them off with a little twist or are they locked in with a nut?
brewsky
Post by brewsky » Mon Apr 05, 2010 10:08 am
They are pressed on and a devil to remove without damaging.
Protect the face with something and pry up on both sides at the shaft at the same time.
Maybe you won't bend the soft metal they are made of!
redblk63
Post by redblk63 » Tue May 18, 2010 11:15 am
I have been successful taking 4 needles off recently by just grabbing with my fingers and twisting. Twist toward the stop at 0 MPH/RPM until the needle moves on the pin. Then continue twisting while pulling up. It worked for me, but YMMV.
Good luck,
Larry - Pasadena
DONZIE
Post by DONZIE » Tue May 18, 2010 7:38 pm
Well heck I thought everybody knew the trick to use 2 table spoons at the same time like mini pry bars across from each other to pry up
redblk63
Post by redblk63 » Thu May 20, 2010 4:34 pm
I bow to your superior dual-spoon suggestion!
Captain Fantastic
Post by Captain Fantastic » Fri May 21, 2010 10:59 pm
DONZIE wrote:Well heck I thought everybody knew the trick to use 2 table spoons at the same time like mini pry bars across from each other to pry up
GENIUS!!!!
5 seconds and it was off....
I LOVE divergent ideas like this.
dv
