clutch lifter rod
choctaw
clutch lifter rod
Post by choctaw » Sat Feb 27, 2016 3:19 pm
how can you tell if your clutch lifter rod is bad. One end is round,the other has a small indention where the ball-bearing sat. thanks. mike
Post by G-Man » Sat Feb 27, 2016 3:42 pm
Look to see if it is straight. Roll on a flat surface.
Check for grooves where the oil seal runs on it...
