ca77 gear shift fork question
Here are 3 pictures of my forks the one on the left has a burnt spot. Is this ok? the tips are in really great shape and the gear shift drum is really nice and falls into specs easily.also the thickness on the worn areas of both,do they need to be built back up? thank you Mike
- IMG_9749.JPG (507.84 KiB) Viewed 1914 times
- IMG_9750.JPG (508.12 KiB) Viewed 1914 times
- IMG_9751.JPG (410.45 KiB) Viewed 1914 times
Re: ca77 gear shift fork question
Please show the sides of the rollers and the point nearest the end of the drum. .............lm
choctaw wrote:Here are 3 pictures of my forks the one on the left has a burnt spot. Is this ok? the tips are in really great shape and the gear shift drum is really nice and falls into specs easily.also the thickness on the worn areas of both,do they need to be built back up? thank you Mike
