shock upper bushings ?
s2000erick
Ohio cycle parts
Post by s2000erick » Sun May 31, 2015 10:23 am
If you can't work it out, PM me your requirements and I will try to work it out for you.
R100
Post by R100 » Sun May 31, 2015 10:24 am
I will ask D.S. Spares if they are ever going to get them again.
R100
Re: Ohio cycle parts
Post by R100 » Sun May 31, 2015 10:34 am
s2000erick wrote:If you can't work it out, PM me your requirements and I will try to work it out for you.
Will do. Much appreciated. Are you close to them?
s2000erick
Post by s2000erick » Sun May 31, 2015 10:39 am
12 - 15 miles and eventhough I have begged I have to do business the same way as all others.
R100
Post by R100 » Sun May 31, 2015 10:45 am
s2000erick wrote:12 - 15 miles and eventhough I have begged I have to do business the same way as all others.
When I hear back from D.S. Spares, I will let you know. And thanks again.
R100
Post by R100 » Thu Jun 04, 2015 3:04 pm
Well I was getting increasingly annoyed thinking about company shipping policies, having to ship twice, and time wasted. Grumble grumble.
Two little rubber rings!
Rummaging through my shelves I found some leftover automotive heater hose. Made a little jig to hold the hose and an Olfa knife, and cut some appropriate short bits. Tight fit on the frame. The outside was a bit fat so I put it on a piece of dowel in a drill press and ran it against some emery backed by a square board. The eye of the shock was a little too tight to go on easily, but silicone grease, and working it while doing up the acorn nut, coaxed it on while the two bushings found their happy place.
Up side -
they are a good fit and will work just fine
I am finished
$0.00
The smile I get when "whatever you got engineering" works out ( it doesn't always)
Down side -
I sometimes drive myself nuts.
And thanks again s2000erick.
Post by G-Man » Thu Jun 04, 2015 3:07 pm
Great job!
