Help, have spark, bike ran, now not so much
Post by LOUD MOUSE » Thu May 29, 2008 7:56 pm
Surely you are not serious!!!!!!!!!!!!!!!. ................lm
<<<<<<<<if you kick it over and it wont start, take the carb off and if youve got raw fuel, move the needle leaner. no fuel, move it richer....hopefully this gets you running.>>>>>>>>>
Foose wrote:tuning carb consists basically of the air screw and the position of the clip on the main needle... the pw22 takes 1 to 1.5 turns out on the air screw, which is what i have on my 64 ca77; the other carb is something like 1 to 1.25 turns out.... hope that helps. as for the main needle, the bike needs to be running for you to really decide if youre rich or lean.
RIDE IT DON'T HIDE IT!
Foose
Post by Foose » Thu May 29, 2008 8:35 pm
??? perhaps im going about things incorrectly? please, guide my fledgling mind... my dream does have some strange tuning issies that i need to discuss with you all soon, but im trying the easy things first....plugs, wires and plug caps... it doesnt like to run except for on the richest setting, and even then i cant seem to get it to come down to a reasonable idle using the air screw... also, if you goose the throttle, she climbs way high and stays there for a bit....suggestions?
thanks...
milwaukeephil
Post by milwaukeephil » Fri May 30, 2008 8:18 am
Hey guys,
Turns out the problem with my carb was the slow jet -- I had cleaned it and blew through it and what I thought was air going through turned out to be just a bad seal between the jet and my lips... live and learn.
I got it cleaned and reamed until I could see a pinhole of light and then it was just a matter of tuning the carb. The bike now starts on the first kick and runs great. Thanks to all you guys, and LM, you're alright no matter what everyone else says about you ;-)
