CB77 Carb Needle ValvesCB77 Carb Needle ValvesHi,
The needle valves are worn in the carbs on my CB77 - one has a visible score mark around it. The bike runs ok but is running too rich, so I would like to replace the worn parts in the carbs. Does anyone have any experience with aftermarket needles valves? - Keyster and Sudco are the ones I have come across so far. If anyone has fitted either of these and had good or bad experiences I'd be grateful for advice. Or if anyone knows of a source for NOS needle valves at all? Thanks, Steph.
Re: CB77 Carb Needle ValvesWhat is a Needle Valve?. ..................lm
Steph
I assume that you mean the needle attached to the carb slide? I bought some OEM ones and the jet that it runs in from David Silver a month or so ago. Have you tried adjusting the position of the needles? PM me and I can send you some carb tuning guides. Graham '60 C77 '60 C72 '62 C72 Dream '63 CL72
