305 Dream Carb Rebuild
Johnm32073
Post by Johnm32073 » Thu Feb 02, 2012 6:01 pm
I have a 1966 305 Dream . It ran find till one one day I tryed to rebuild the carburetor (PW22) CA77 engine and I really messed that up. Does anyone know of anyone that I can send this carb to that rebuild it? or anyone can tell me how to adjust the needles in it That is where I messed it up
john in Jacksonville Fl
brewsky
Post by brewsky » Thu Feb 02, 2012 6:26 pm
Welcome to the forum.
You can probably fix it yourself if you are at all mechanically inclined.
What have you done to it already since it was running?
Re: 305 Dream Carb Rebuild
Post by LOUD MOUSE » Thu Feb 02, 2012 7:38 pm
I do rebuilds of that carb.
Get in touch PM. ........lm
Johnm32073 wrote:I have a 1966 305 Dream . It ran find till one one day I tryed to rebuild the carburetor (PW22) CA77 engine and I really messed that up. Does anyone know of anyone that I can send this carb to that rebuild it? or anyone can tell me how to adjust the needles in it That is where I messed it up
Johnm32073
Post by Johnm32073 » Fri Feb 03, 2012 12:26 pm
Brewsky I took it apart and put it back together.Then again I know about Carburetor.(motorcycle or Cars) But I can do engine work I did count the 1/2 turns it took to to remove the jet screws and put them back the same turns.
I did get a rebuild package for my petcock, but the gasgets that came with it for the bowl warps and deforms when fuel sets on it for a while causing it to leak like crazy That may be some of my problem
Johnm32073
Post by Johnm32073 » Fri Feb 03, 2012 12:36 pm
LM,, I Want to get in touch with you about you rebuilding the carb. Going to work tomorrow I will be gone two weeks about it.
brcree
carb idle....
Post by brcree » Sat Feb 25, 2012 12:43 pm
Can I but in here and ask?........I rebuilt my carb., CA77........and need to know where to set air/fuel needle and the idle needle at for my first start up.
In God we trust!.....Nothing like some breeze on the knees!
brewsky
Post by brewsky » Sun Feb 26, 2012 5:02 am
Mix screw (closest to engine) .........1 1/4 out from lightly seated.
Idle speed screw, .....turn in till you can just feel the slide starting to move up from bottomed out.
Wait till the engine is completely warmed up before making final adjustments.
